SOURCE: My Maytag Front Loading Washer Does Not Fully Rinse Cloths MAH8700A
A friend had this problem and was ready to buy a new machine. Sometimes it worked and sometimes not. I took a last look before new machine and found a coin that would intermittently block the pump/discharge port on the machine.
SOURCE: Neptune MAH3000AWW Problems
yes ginko is right something like money might be traped in the tub
SOURCE: Maytag neptune washer
check your cold water filter at the valve where it enters the back of the machine make sure cold water enters the machine.take the cold hose of and make sure it is clear.
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
SOURCE: dc code appears only when clothes are in washer during spin cycle
If it’s an FAV6800A I think you may have a clutch malfunction with your machine. To verify if the clutch has malfunctioned we need to perform a quick check. Please visit this link and review my post of Solution #1 posted on Jan 30, 2009. Steps 1 & 2 should get you started and give us some troubleshooting direction. Please post back with your results or if you have any questions.
http://www.fixya.com/support/t1612027-maytag_neptune_fav6800aww_wont_spin
Good Luck… Rich.
