Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Posted on Jul 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio output device - Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Ginko
Level 3:
  • Microsoft Master 19,396 Answers
  • Posted on Jul 20, 2011
Ginko
Microsoft Master
Level 3:
Answers
19396
Questions
25
Helped
8074456
Points
55462
Hi.
The audio output device in your computer is the audio adapter board (or circuit). This is the device that produces sounds and send them to the speakers.
If you get a message telling you that there is no Audio Output Device detected, or that the Audio Device is not working, that usually means that there is a problem with the audio driver.
In that case the problem is often fixed downloading and reinstalling the drivers for your audio device. If there is a problem with the audio output device, go to the computer manufacturer website (e.g. Dell, HP, Sony etc.) and download the audio drivers for your specific model. When download is complete install the drivers and restart the computer.
Regards.
Ginko
How to output sound to a 2nd device
If you need an analogue output, you can tap stereo analogue audio by using one of the two sets of "pre-out" RCA jacks on the back of your receiver. These provide "headphone like" output power, and will not overload any analogue input connected to it EXCEPT MIC and PHONO inputs on the 2nd device. If it's digital audio output you need, there's an HDMI monitor out, that will provide digital audio to another HDMI input equipped device. You'll have to get a relatively cheap adaptor if you need this digital audio output in another digital format/connection (like the popular S/PDIF optical or coaxial).
2answers
I wanna connect my laptop(lenovo G450) to samsung series 4 lcd through hdmi cable
A HDMI cable can output both audio and video, whilst some computer with Windows XP cannot automatically switch to HD Audio output as Windows 7 can. Thus manual setup can solve the problem.
After connecting the HDMI cable, Go to "Start" > "Control Panel" > "Sounds and Audio Devices", double-click "Sounds and Audio Devices. Select "Audio" tab on "Sounds and Audio Devices Properties" window.
On "Sound playback", change "Default device" from "Conexant HD Audio output" to "NVDIA High Definition Audio".
Your television should have several HDMI ports, select the appropriate HDMI port number and check if TV is not muted.
Hope this helps.
3answers
My pc says no audio output device installed,but in device manager it says its working properly and the drivers are up to date
Well it is possible that the audio driver installed is not the one compatible with you computer board. Try downloading the specific driver needed for your computer's official website. This should solve your problem.
My pc says no audio output device is installed
You have to install the audio driver for the audio device first. As for the output audio it is for speakers connect/plug into to the output audio port.
2answers
No audio output device installed and the screen goes off when connected to a projector
For no Audio output device installed message, go to device manager uninstall the audio driver. Reinstall the audio driver from either Windows update or from the manufacturer's(your Computer or Laptop) Web site.
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
1helpful
2answers
Reinstall audio output device on laptop
you might have deleted the driver for your internal sound card go to the laptops manufacturers website and see if you can download the driver again, then reinstall it.
3helpful
2answers
You need to reinstall the drivers. Get these from support.dell.com
Deleted audio output device on Microsoft Office Home Edition
Hi!
Take mother board cd and install audio drivers....That's it..
bye & take care....:)
2answers
NO AUDIO OUTPUT DEVICE IS INSTALLED
its a known issue --if you u upgrade vista home to vista ultimate.just u need to uninstall the audio driver and install it again
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
