Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Dewalt cordless drill
I've have a 18 v hammer drill and was drilling holes in concrete drill stopped working and a new battery started to smoke and almost caught fire. The drill no longer works, the reverse switch does not move.
    New Friend:
18v xpr dewalt drill smells like buring then eventually stopped working or Intermittently works.
Posted on Apr 03, 2011
  • xMichigander Sep 05, 2014
    they updated the brushes in some of the older 18v drills yours might be one of those. also the problem might be in the variable speed controller.
    Top Expert:
  • Dewalt Master
  • 85,222 Answers
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Posted on Aug 29, 2008
6ya staff
SOURCE:
Hi. I was drilling a few holes in concrete with my TE 56 HILTI and the drill bit become jammed. it began to smoke so i put a new set of brushes in it and still the same spins slow and smokes, any...
It sound like is has overheated or a bearing has seized. Take it to hilti. www.hilti.co.uk for nearest dealer. They will collect for a price.
Dec 11, 2012 | Drills
Milwaukee 18V Hammer drill shuts off while drilling
Brushes to the motor could be the cause or heat sensor in the battery pack it switches off or even bad connections on motor check the spades connections could be loose
May 13, 2017 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
I have 3 drills, (2)14.4 and (1)18 volt Dewalt. the 14.4 drills starT to smell of burning and then smoke. One of the 14.4 drills seems to be less powerful. The 18 volt hammer drill is stuck in forward...
Well burning and smoke is either a switch or motor. Disconnect the motor and run it with battery voltage and no switch. If it's still slow and smokes it's the motor if not it's the switch. The other one sounds more like the switch but could be the motor. Testing would be the same as the other. On the 18 volt open it up and see if the reversing lever got hung up. It may be that you can line it back up and be ok. More likely it's a bad switch and needs to be replaced.
All these tools have static sensitive switches and need to be worked on at a static free work station.
Hope that helped..
Oct 16, 2011 | Dewalt 18 Volt Compact Drill Kit
I have a dewalt 18v cordless hammer drill but for some reason while drilling the drill does not spin as fast as it used to batteries are fine just the drill any ideas
depends on where you drilling- wood - no hammer option needed- fast, metal- no hammer option needed- also fast, but it is concrete- sorry- hammer option needed so it will always drill slower, and drain your batteries way faster (have a spare one ready).Speaking about drilling - don't drill for too long with no breaks to cool them down, always keep an eye on gun's and battery's temperature- even if it is new Lithium NANO, do not let them overheat.
BTW- what model is yours? Is It SDS hammer drill sort of DC212KL?
May 19, 2010 | Dewalt 18 Volt Compact Drill Kit
Motor burned out smoke came from rear of drill. replace motor?
Save the battery and charger and forget the drill. I blieve the motor woul cost you at least half price of new. Go to the dewalt replacement site to find out
Aug 16, 2009 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
When I was done using the hammer drill to drilling
open your chuck as far as it will go look down inside the chuck and you should see where it has come from ,if that is where it came from it will be right hand thread probably allen key or very small socket
Aug 14, 2009 | Milwaukee 0824-24 V18 1/2" Hammer Drill...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
1,298 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
