For an inkjet, make sure that the printer is on (plug in and turn on for a new printer). Then open the top cover and wait for the cartridge carrier to come to a stop at the left side of the printer. Then remove the old cartridge (if needed) by pushing the cartridge down to a slight angle then pull it out of the carrier. Open the new ink packaging (one cartridge at a time) and remove the tape (do not touch the electrical contacts or the nozzles). Insert the cartridge into the carrier (black on the left) at a slight angle (towards you). Then push the cartridge up into the printer cartridge carrier. Repeat this for the other cartridge then close the top cover. (The light will blink orange if the cartridges are not correctly seated or both cartridges are not installed.) Wait for the green light to stop blinking before sending a print job to the printer. (The printer needs time to charge the system with the new ink.)
For pictures, see the set up guide: http://gdlp01.c-wss.com/gds/6/0300000636/01/iP2600_ESI_EN-US_V1.pdf or the Canon support site: http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip2600#ServiceAndSupport . Search for "replace ink cartridge".
If the ink cartridge carrier does not move to the left, check for any foreign objects blocking the path of the carrier. Some inkjets have a plastic guide (usually clear or translucent) that needs to be connected to the cartridge carrier. Shift it down and into position. Other inkjets can have smudges on the guide that can block motion of the carrier. (Clean with a soft lint-free cloth without removing grease from other components.)
I hope this helps.
Number following "E"
Cause
How to correct
No paper. /
Paper does not feed.
If paper is not installed, load it
and then press the <Black> or <Color> button. When paper is
installed, check each of the following items and try printing again.
1. Confirm only recommended paper is installed.
2. Confirm paper is installed properly.
3. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
4. Clean the paper feed roller to resolve the error.
Paper jam
Remove the jammed paper.
If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
Empty ink tank
An ink cartridge is empty.
To cancel printing, press the <Stop/Reset> button.
To continue printing, press <Black> or <Color> button.
After printing completes, replace the empty ink cartridge.
Printing with an empty ink cartridge may cause the machine to malfunction.
5
The ink cartridge(s) is not installed. / The ink cartridge(s) cannot be recognized.
The ink cartridge may not be installed properly, or an unsupported ink cartridge may be installed.
Install a recommended ink cartridge.
Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing.
If one of the ink cartridges is missing, this error can occur.
7
The ink cartridge is not installed in the appropriate position.
The ink cartridge is not installed in the proper position.
Install each ink cartridge in the proper position.
8
The waste ink absorber is almost full.
The waste ink absorber is getting full.
Press the <Black> or <Color> button to clear the error and continue printing.
Printing
can continue until the waste ink absorber becomes full. If the waste
ink absorber becomes full, the machine will require service.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
9
A specified period of time has
elapsed without receiving a response from the digital camera. / A print
mode compliant with PictBridge is not selected. / A specified period of
time has elapsed without receiving a response from the digital camera.
The machine cannot communicate with the connected camera.
Disconnect the cable between the machine and the camera to clear the error.
Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the machine cannot print directly from the camera.
2.
Set the camera in PictBridge print mode before it is connected to the
machine. This is required before printing for some cameras that support
PictBridge.
Please refer to the camera instructions for more
information about procedures required before and after connection to the
machine.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the machine.
1 , 4
1 , 5
The ink cartridge cannot be recognized.
An unsupported ink cartridge may be installed.
Install only recommended ink cartridges.
1, 6
The ink level cannot be correctly detected.
A used ink cartridge may be installed, or the ink cartridge is empty.
Replace the ink cartridge.
Press the <Black> or <Color> button, to clear the error
and continue printing without replacing the ink cartridge. However, the
remaining ink amount cannot be detected properly, so the function to
detect the remaining ink amount does not operate.
1 , 9
Scanning failed.
Scanning a document failed.
Check if the document is placed in the correct orientation / position and try the operation again.
2 , x
3 , x
4 , x
(Where x represents a number)
Turn the machine off, and remove the power cord from the electrical outlet.
Wait approximately ten minutes then plug in the power cord and turn the machine on.
If the problem is not resolved, the machine may require service.
