Push the X button on the printer.Doing so will cancel the current print job.
Click on the printer icon at the lower right hand corner of your screen.
This will bring up the print spooler dialog. Make sure the print job you want to cancel is selected.
You will find the Cancel command in the menu.
Hope this helps.
SOURCE: Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
SOURCE: X5150 and Vista print issue
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
SOURCE: printer will not cancel print job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This
will restart the print queue and will probably try to print the job
again or delete it properly. If it tries to restart, just right click
on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
SOURCE: printer stopped working after I cancelled a print job
SOURCE: How do I cancel print job. I get message access
OPen the printer program, select the jobs and select cancel.
go to the control panel to find the printer program
