SOURCE: is it possible to send two suffix in symbol ls2208
Yes it is possible.
You will need to create the following adf rule which you can do using 123scan.
the barcodes generated will be the following:
Begin new rule.
Send all that remains
Send Extended key <Enter>
Send extended key <Enter>
Save Rule.
If you can't generate them, I can send you a pdf document with them already created.
SOURCE: Will not read barcode correctly
La configuracion por defecto en el lector puede necesitar cambiarse para el tipo de codigo de barras que intentas leer. Descarga el manual para cambiar los parametros del tipo de codigo de barras que intentas leer. The default setting in the reader may need to change the type of barcode you are trying to read. Download the manual to change the parameters of the type of barcode you are trying to read.http://www.ute.com/files/manuals/103_MS210%20Users%20Manual.PDF
SOURCE: Need to add prefix ~ and suffix / for ls2208. I
Have a read through this document.
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
look at 13-4
have you tried scanneing the enter barcode after 6 ?
SOURCE: I have a Symbol LS2208
HI
Download the Manual for LS2208 and go to page no. 255 there you will get you solution. for manual click hear.
Cheer
