Posted on Jul 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When printing multiple copies the font changes to nonsense
Piyal Perera
Level 3:
  • Master 528 Answers
  • Posted on Jul 22, 2011
Piyal Perera
Master
Level 3:
Answers
528
Questions
0
Helped
165519
Points
1520
Go to printer properties and see whether 'Paper source' has being set to 'Manual feed'.
Then change it to 'Auto Feeder' or 'Auto'.
(Different words might have been used in different printer models instead these words)
This is a suggestion. This might work or might not. Have several papers ready in the Auto tray (usually at the bottom) before printing.
How to change font size
You can try a work-around it by copying the text into another program like Word or WordPad, adjusting the fonts and then printing.
Font changes
in text editor source printing if U can not change font tipe and size copy text in wordpad or libreoffice and edit text then print
How do i change the size of print on my Lexmark pro250
Do you also get the same font size result when making a copy using the Copy button from the printer operator panel?
It could be due to the print setting on the application that you're printing from. e.g. If you are using Word application, go to File > Page Layout > select Fonts and choose your preferred font size.
How do I change font (to readable size) when printing out from internet when there is no choice indicated
IF YOU RIGHT CLICK YOUR MOUSE YOU CAN SELECT COPY ALL THEN PAST INTO MICROSOFT WORD THEN CHANGE THE FONT SIZE OR YOU CAN SELECT PRINT CHANGE PRINTER TO ADOBE CONVERT TO A PDF THEN PRINT
1helpful
I have a photosmart 4650...when I print from a web page, the print is so small I cant read it. How do I change the font size?
Best Answer -
That entirely depends on what you are printing. A printerwill only produce what it is given.
If you are printing your own document then you change the font in the documentbefore printing or select the font before you start.
However I suspect the reason you are asking this is because you are printing apdf document from the internet. In which case the font is fixed.
If so, then you will have to copy and paste the document in to a word processorlike Word, highlight it all and the increase the font. You will then have toreformat the whole document as the increased font will throw the orginalformatting all out of line.
When you have straightened it all up then print it off.
ALTERNATIVELY, if you are printing on ordinary web page then you need to follow the below instruction
Instructions
1. 1 Go to theweb page that you want to print and right-click it. Click "PrintPreview." If you want to print part of the page, highlight the contentthat you want to print and right-click the selection. Click "PrintPreview." 2. 2 Click the "Page Setup" icon located onthe top of the Print Preview window to launch the Page Setup dialog box. Click"Change Font." 3. 3 Select the font you want to use in the"Size" window. If you want to change the font type, make yourselection in the "Font" window. Click "OK" to save thechanges and click "OK" again. 4. 4 Turn on your printer if it is not on. Click the"Print" icon on the Print Preview window to print your web page.
My printer prints email etc. but will not print anything from my computer...example: word documents
I assume you mean that you can print from Outlook or other e-mail program (Outlook Express, LiveMail, Thunderbird). Are you reading your e-mail on the same computer that can't print Word documents?
If yes, one thing to try is to change the font on the Word document. For some reason, certain fonts just do not work. (Most often it is an issue with a document (or template) created on a different computer (or before upgrading the OS) and the font info gets scrambled in the transfer.) Just select all (control-A or Edit, Select All) and choose a new font. If the document has multiple fonts, do not use select all but highlight the sections separately and change the font.
If it is a different computer, check that the network is active and that all the correct drivers are installed. (One thing to check is a Universal Print Driver (UPD) software needs both the 32 and 64 bit drivers if the network has a mix of OS's. This comes up when the printer is attached to one computer and it serves as the print server.)
How do I change the font size of the printer when trying to print emails?
Print functionality depends largely on the email client. If you are using your browser you can use the view settings to make the fonts bigger and print. Or you can copy and past the text into a text editor and change fonts there.
When printing from websites... text prints in very, very tiny font size. How do I change font size??
Well before printing, you can copy & paste it on a word document. After that, increase font or change colour.
OR
You can do file \ print \ properties \effetcs tab \ % of normal size! Here you can increase the size using the slider.
Please send us your feedback & vote to help us help you as it should be.
3answers
How do i change font size on HP 6110 xi printer
The manual doesn't list scaleable font size as a feature. You will probably have to set your font size in the document you are making.
k24674
ADMIN Andrew
ADMIN Andrew
