Question about Xerox DocuPrint C4350 Laser Printer
Error code 024-747 is given when trying to print a specific Word 2010 document although any other Word 2010 document seems to print without any problems. Can you tell me what this error message means and do you have any suggestions how to get round this?
  • vladimir_sir
    vladimir_sir Jan 23, 2013
    In my case such kind of issue was when i tried to print from MS Word and Excel from WC 5020 and WC 7120 - Solution: in "paper type" option set "Original document Size" as same as paper size you want to print and it will work!!!
  • Muhammad siddique khan
    Muhammad siddique khan Mar 03, 2016
    please resold the issue
    New Friend:
In my case was like when i tried to print MS Word or Excel document (Xerox WC 5020 & WC 7120) i had to set "Original document size" in Paper Type option as same as "Output document size" in Printing preferences - it should help.
Posted on Jan 23, 2013
2 Suggested Answers
Anonymous
SOURCE:
Rick Kasper
  • 2072 Answers
SOURCE: Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Posted on Feb 04, 2008
How do I print without a border please 8.3 by 11.7
Margins are set up in your WORD processor. Presuming you are sung WinWord, you should seelct
PAGE SETUP
and succesively adjust Margin, Orientation and Size.
Be careful that size of paper seelcted be the same size of the paper you are sung.
Microsoft Word tutorial How to print booklet lynda com
MS Word Print Preview Tutorial
Word 2013 Tutorial Previewing and Printing Documents 2013 2010 Microsoft...
Word 2010 Tutorial Previewing and Printing Documents 2010 Microsoft...
Sep 24, 2015 | Office Equipment & Supplies
Project 2010 - Unable to open file error
This is vital point which can be consider as workaround:
v Go to the document library in which project files resides
v Hover your mouse to any project file and select 'edit in Microsoft Office Project'
v It will give you a pop up by selecting the 'SharePoint drafts' option
v Click ok / you can do a check out also by selecting the 'SharePoint draft' option
v Now the document is in check out condition so go to the SharePoint drafts location on your machine (Location: \My Documents\SharePoint drafts)
v Open the document by means of draft location, do the changes and save it.
v Go back to the SharePoint site and check in the document.
v Changes will be successfully saved without any problems
Try to install this app Recovery Toolbox for Project
http://www.project.recoverytoolbox.com/
Here's one thread like yours. It could be useful for your, read http://www.filerepairforum.com/forum/microsoft/microsoft-aa/project/625-project-error-"an-import-error-occurred"
Dec 03, 2014 | Microsoft Office Project Standard 2007 -...
Lexmark printer help
In windows clear out the print spooler and that will erase anything in the queue to be printed. Google will tell you specifically where to go to do the deed.
Aug 26, 2017 | Lexmark X9575 Wireless Professional...
HP PRINTER LASER JET 600 ERROR 59.00.90
www8.hp.com/us/en/support.html
http://www.printertechs.com/printer-troubleshooting/hp-error-codes/195-numeric-error-codes-50-59-hp-laserjet
Jun 17, 2014 | HEWLETT PACKARD - LASER JETS HP LaserJet...
My printer, HP 8500, has been trying to delete a document for hours with no apparent results. I am unable to print anything else although it does put a new document in queue. I do not get any error...
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Jul 02, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
When trying to print an 11 x 17 word 2010 document that displays properly on the screen only a portion approximately 8.5 x 11 prints out of my 3 month old HP business Inkjet 2800 printer.
It may be that an updated driver is needed; that would be available from the HP website. You should be able to manually set the printer via the HP user software that came with it although it seems that Word should be able to do that automatically.
Sep 09, 2010 | HP Business InkJet 2800 Printer
I cant print word documents. It says printer is
I have encountered this problem, wherein I can print webpages, excel, pdf files, but not in Microsoft Word.
I received error "Windows cannot print due to a problem with the current printer setup".
I got it resolved by following the instructions given by Microsoft: http://support.microsoft.com/kb/826862
Specifically the steps under 'Delete the Word Data key'.
Oct 14, 2009 | Office Equipment & Supplies
Unusual character where special character or underline is given
If you have a spare USB cable around the house, try that first and see if the cable was bad.
Aug 21, 2008 | HP DeskJet 640c InkJet Printer
Xerox DocuPrint C4350 Laser Printer Logo
32,796 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
