SOURCE: Dewalt 18v. cordless drill
Hope to help.
hope your wife is ok!!
you need to get all the hair out firstly but DO NOT touch the exposed switch as it is a static switch and can fail by the tatic in you!
the problem may be that the brushes were damaged try replacing them see how that goes.
hope this helps. Sean
SOURCE: dewalt dc 988 cordless drill
posible motor problem, the built in magnetic ring in the motor may broken inside or just to much dust in it. advice when replacing motor also replace th switch for the cost $132.00 plus tax canadian. thanx
SOURCE: Dewalt dw997 drill clutch stuck
your drill required trans assy & clutch assy for $132.00 plus tax canadian max repair/
thanx
SOURCE: looking for repair manual for Dewalt DW87 cordless drill
Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom. From there you should be able to download a schematic and some of the parts are component parts and don't have a lot of replacement items. It sounds like you broke the clutch or gearcase and both are components.
SOURCE: dewalt 18 volt cordless drill
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
