Question about Asko Washing Machines
F4 error code - Asko Washing Machines
  • presciniti Aug 29, 2008
    I have an ASKO washer, W6461 Quattro 1600RPM.
    I have already tried to the general advice given in the Troubleshooting section of the guide (i.e. I know water is coming out of my water source and it does not look like there is anythintg clogging the filter in the fitting that the hose ties into on the machine).
  • Cameron Viseth
    Cameron Viseth May 11, 2010
    we need to know what the make,series and model of your washer.
  • 594 Answers
Unfortunatly i can not find any support for your washer you can contact them at www.asko.com
Posted on Aug 30, 2008
6ya staff
SOURCE:
Please , may i know f4 error code in split type air conditioner
Here is error code f4
light fan motor of indoor
1?Check whether the contact of the plug of the motor wire 8 unit fault and socket is well, making sure well contact.
2?Check whether the indoor motor has damaged, the motor should be replaced when it is damaged.
3?Check whether the controllable silicon and other components on the electric control board have damaged, replace the controllable silicon or electric control board when they are damaged.
click on the link below and scroll down the left side to find error code f4...CHEERS
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
Mar 20, 2016 | Heating & Cooling
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
Getting error E1 checked all as per manual but still getting it
Whirlpool dishwasher F4 F8 FA error code ... - YouTube
? 1:57
www.youtube.com/watch?v=RfeFTdSdNYQ
May 27, 2012 - Uploaded by ukanfixit Although the Whirlpool dishwasher F4 error code is "not draining" it is actually a .... switch situated? my Whirlpool showsE1 and F8 error codes.
Aug 24, 2015 | Whirlpool Dishwashers
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
Error code F4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 04, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
F4 error code on Jenn-Air W30400BC expressions built in oven
Slone, F4 is the code for a shorted temperature sensor. This is the temp probe in the oven. There are 2-quarter inch screws holding it on. It should pull out through the insulation until the quick connect comes through. If you want to make sure, the sensor should ohm out at 1143 ohms at 100 degrees. I think you can be pretty sure that this is the problem. The part number I have is 704657. Catriver.
Dec 04, 2007 | Jenn-Air JJW8527C Expressions Collection...
Washing Machines Logo
309 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
