SOURCE: Grinder reassembly
Email me your email address and I will send you a pdf of the grinder cleaning instructions that will explain how to align your grinder. Email: [email protected] Johnny
SOURCE: I had difficulty removing the brew group when
You may have disrupted the brew unit switch. You will probably need to replace this. It is a fairly complex repair. Look for a repair center near you.
SOURCE: The burr grinder grinds and
For smitty_2007 you may have to also clean the grinder. Instructions should be in the manual. Remember when doing so there is a slot on sode where grinder goes that the coffee pushes out. Sometimes that will get packed and need to clean also.
SOURCE: grinder jammed
I'll explain how to in general, you have to work out the rest...first remove 3 screws on the coffee container...and 3 again underneath.To remove the sides..undo 6 T10 screws on RH side and 3 on LH.Then pull the front knob off and remove the coffee spout.Remove the top cover.Check the grinder whether itis accessible from the top ,if not remove 5 phyllips screws that hold the top half.Lift up and pull the grinder out. Good luck!
SOURCE: Steady Brew Group Light: Old Saeco Magic deluxe
Open the door on the right. The brew unit is the thing with the handle that has the push on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed, so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
