Check that you have a spark at the plug. You can use a plug tester or hold a plug against the engine. (Hold the cap not the plug!). Check you have fuel to the cylinder. After trying to start is the faulty cylinder spark plug wet, does it smell of fuel? If not check the valve clearances on that cylinder. If all that is ok, check the ignition timing.
Hi, check the valve clearances, regards Phil.
