SOURCE: only one side sends out sounds
Usually the wires are so small that they are hard to repair even if you can open the units to re-attach. I think they make these things to break.
The wires break at the flex points.
SOURCE: I have Seinheiser HD 202
The fault is in the cable: you will have to dismantle the left speaker housing and start cutting from the cable until the break is removed then solder it back to the speaker - use an multimeter to check the continuity of the wires.
SOURCE: The left ear phone broke
Take your headphones into the nearest Bose Audio store. Depending on the amount of time you have owned the headphones, you may be able to get a replacement or a discount on new headphones.
