According to Microsoft it is compatible for Windows 7, you also can download supported updates packs from Window Update, it keeps you up to date. If you will face problem to use it after installing, please keep the following steps in mind:
You can try the following methods Method 1: Put the computer in 'Clean boot' and check the status. http://support.microsoft.com/kb/929135 Note: When the troubleshooting is over do not forget to reset the computer to normal startup. Follow step 7 in the above article. Method 2: You can try to open the program in compatibility mode and check the status. Make older programs run in this version of Windows http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows Open the program as an Administrator Right click on the file and click on the 'Run as Administrator'
