To reset the watch, you need to 'short' the reset point with the battery. To do this, with the watch face down and the back removed the 'Reset' point is in the bottom right hand corner (a gold-coloured contact point). Use a pair of metal tweezers or an unbent paper-clip (anything as long as it's metal and will touch the reset point and the back of the battery at the same time). Maintain contact for about 5 seconds and you should get the display back.
I've just changed the battery in my SDB 500W and the above method worked. I did lose the audible 'beep' though and I'm currently on the net trying to find how to get it back. That's how I found your question... :)
Still got the spring. Trying to re-establish contact with the back of the watch! Thanks.
Update: I got my beep back! The beep worked with the top two screws in but didn't when the bottom two screws were in. I think the problem was the spring clip holding the battery was arched slightly and touched the piezo speaker when the bottom screws were inserted, so I made sure the battery clip was flat, screwed the back of the watch beck on ... and the beep came back. To say I'm relieved would be an understatement.
nice one
make sure youv not lost the small springhttp://forums.watchuseek.com/f43/how-cha...
sommerzeit einstellen
