The only Whirlpool washer with an F35 code that I know of is the Duet. For that washer, the code indicates a failure of the analog pressure sensor. Check if the pressure hose is connected properly. Check that the hose is not blocked. Finally check for a blockage in the airtrap. If the hose and airtrap are fine, then the sensor or the related circuitry is bad.
I hope this helps.
