computer probly needs to be flashed or reprogrammd to sync w new motor---some independent shops have the factory gear to do this-dealers only go back like 5yrs
Cheapest scenario is to change the transmission filter. That is if it is an automatic. When you do this, most transmissions have a magnet in the transmission pan. If yours has one I would check it for excessive metal shavings or worse metal chunks.
There is a vehicle speed sensor on top of the rear differential, this sensor is also for the anti-lock brakes. Sometimes you just remove it and clean it (it's magnetic) and may start working again otherwise you have to buy new. Yes, this sensor will affect the trany shifting.
Your transmission is in a "limp in" mode. There are 2 sensors that need replaced. Total cost should be less than $100. I had it happen to me on my 99 300m. The sensors limit the speed to about 25 mph and the RPM rev's high. Just get the sensors replaced.
i can answer part of your question. the front wheel speed sensors are for abs and trac control only. these will not affect the speedo your problem is some where else. sorry i have not had this prob yet good luck. you could have to replace the rear wheel speed sensor again. they are not that good. and after market are even worse.
