That's very nice of you to try and help your blind friend, if you can see the model number on the back of the watch itself where you took off the back, or maybe it is on the face with a watch. Then you can start a Google search from there. Honestly? If I were to call you, I would just tell you the exact same thing :-)
SOURCE: watch doesn't talk anymore
If the battery is not visible by removing the back then this is not a battery change that I recommend for the layperson. I suggest taking this to a watchmaker or technician. This is because the battery powering the circuit board for sound maybe under the circuit board and not easily accessible without removing the movement and separating the circuit board from the movement. Also you should know that these sound boards are sensative and can easily be damaged.
