If the fault started ONLY after the batteries were replaced, it is important that in the first place if the battery was leaked and oozed onto to the board.
if so you need to open and clean the board. Also make sure that the contacts of the battery are clean, If not there is fault in the board, it will be good to remove, clean , heat off moisture and reset.
