Nokia N73 Cellular Phone Logo
Posted on Jul 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
N73 back door open camer not open - Nokia N73 Cellular Phone
Maddy Thapa
Level 2:
Sniper:
  • Expert 80 Answers
  • Posted on Jul 26, 2011
Maddy Thapa
Expert
Level 2:
Sniper:
Answers
80
Questions
Helped
14461
Points
385
It may be 'coz your camera lock has been broken... change the body of your nokia n73 and then try....!!!
Craftsman garage door opener remote
measure the battery from r.control and if it it low replace, clean the contacts battery. open the remote control and clean the keypads from dirty, corrosion, oxide, and try again. see the picture. use the digital camer or webcam cell, The LED must be TURN ON, if not proceed with the steps before mentioned.
1helpful
How to remove memory card my n73
The memory card slot for Nokia N73 is located at the bottom of the keypad just above the charger connector.
  1. Before you eject the card, press the power key, and select Remove mem. card. All applications are closed.
  2. When Remove memory card and press 'OK' is displayed, open the door of the memory card slot.
  3. Press the memory card to release it from the slot.
Do not remove the memory card in the middle of an operation when the card is being accessed. Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
N73 back camera ok but not open whith body cover
* check the back cover (usually run if its still the original back cover),there's 2 gold plated line that hits the 2 pin inserted at the back housing...
* check the 2 pin standing at the back house, take a look if its align and bouncing....
hope this solution helps.... please rate me and you can ask testimonial too... thank you...
My n73 camera is automatic open please helpme
my nokia n73 back camra auto open any time please help me
4helpful
3answers
My N73 back camera auto opens at anytime, closes and reopens again without using the slide
if you have tat problem then there is problem in your back panel if you change it your problem wil be solved
2answers
The battery door on my Vivitar broke off. Can
Try with m-seal which is like cement.You can make a small mould of the part which is brocken and fix it carefully.I have done it many times. This will solve your problem.
When i power on my camers the screen says card-cover open
the switch that controls the door may be going bad.. and would need repair.. but you can try to reset the camera or leave battery out of camera for a couple days
N73
Firstly open the menu- then go to control panel- then log -open it up - optiions clear all log.
u must store your messages in memory card and not your phone memory. Deletae unwanted messages from the message menu.
Open messages- then press options then settings then "others" then "memory in use " select use memory card .
ambove this option is the no of messages that can be stored - there type in 999. Close all and come back. to your menu.
Please feel free if u have some problems
2helpful
Help to open n73 cover
Here is a really good guide for taking the front cover of the N73.
http://www.howardforums.com/showthread.php?threadid=998729
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
