Vehicle Parts & Accessories Logo
Posted on Jul 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dear Mercedes-Benz Experts I have mercedes CL500 mid on 2009 my problem is after pressing on the brakes in high speed the car starts to shake harder, moreover this problem started when i taked a heavy bump before two weeks.
Anonymous
Level 1:
New Friend:
  • Contributor 52 Answers
  • Posted on Jul 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
52
Questions
0
Helped
12374
Points
65
Most likely one or more of your brake rotors were warped (bent) stepping on the brake transfers this into a shake or vibration
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Mercedes-Benz Master 1,449 Answers
  • Posted on Dec 03, 2013
Daniel Mc Entee
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
275941
Points
3556
Change your rotors .and check your pads.
2004 Mercedes Benz 500. Where is the radio fuse box located in it please?
Question edited for clarity.
Question moved to model category.
Mercedes are the only manufacturer to have 8 or 10 fuse boxes :>D Don't forget the radio is also connected and monitored by the BCM.
Mercedes-Benz CL-Class & S-Class (C215, W220
Fuse Box Diagrams https://fuse-box.info > mercedes-benz > mercedes-ben...
Here you will find fuse box diagrams of Mercedes-Benz CL500, CL600, CL55, CL63, CL65, S280, S320, S350, S400, S430, S500, S600, S55, S65 (1999, 2000, 2001 ...
Mercedes-Benz E-Class (W211; 2003-2009) fuses ...
Here you will find fuse box diagrams of Mercedes-Benz E200, E220, E230, E240, E270, E280, E300, E320, E350, E400, E420, E500, E550, E55, E63 2003, 2004, 2005, ...
Fuse box diagram Mercedes w220 and relay with ...
FuseAndRelay.com https://fuseandrelay.com > mercedes
In our article you will find a description of the fuses and relays Mercedes 220 with box diagrams, photo examples and their locations. We will note the ...
Engine compartment · ‎Box on the left side · ‎Box on the right side · ‎Additional box
Mercedes cl500' w215' abc warning on dash
These ABC systems are EXTREMELY expensive and requires a specially trained tech to work on them. Do yourself a favor and ditch the ABC with a Mercedes CL500 Conversion. No more specially trained techs needed to work on the suspension. Just a good old fashioned suspension any mechanic can work on.
1helpful
Code p0705
take it to a transmission shop that has a tech 2 scanner and have them check it out
1helpful
2answers
Why is my mercedes cl 500 window fuse blowing and no power to window or seat now help
The window and seat are controled by the door control module. If the fuse is blowing it is most likly a window motor that is consuming to much current.
1helpful
2001 mercedes cl500 wont start...cranks but wont start. Happend while sitting in the garage. The car earlier in the dat ran fine
Open the air cleaner or intake hose and while someone is turning it over spray some ether into it with no more than three second bursts. If it cranks then you have a problem with fuel delivery and if it doesnt you are looking at something with the spark or ignition.
1helpful
Gear stuck in park, how to remove center console, CL 500 2003
Sounds like your shift lockout is not disengaging when you depress the brake. I don't know about Mercedes but the general way to do it is the solenoid in the console that is actuated by depressing the brake could be bad however i believe the power supplied to the solenoid comes directly from the brake switch. Can't answer your center console question sorry.
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
