I lost my remote to my panasonic omnivision vhs and the settings are messed up its on spanish and my vhs is not working but i use a another vhs soo that is fine and i had 3 or 4 channels and they r gone when i opened it up there was some weird menu and none of the buttons helped than i i pressed the chaneel up button and the channels number stopped working
plz help
how do you select in the panasonic omnivisions menu i can move it around but cant selecthow do you select in the panasonic omnivisions menu i can move it around but cant select
You can't post conmments that contain an email address.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://homenol.blogspot.com/ http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Hi, did the remote come with a manual?if it does,that means you will see the user's guide for the remote about the instruction and the different functions it has.
Also i guess the remote is not a universal remote or the reote is not the exact one for your system.It might not work properly with it...All buttons will not function properly..
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
