SOURCE: DOSN T DRAIN
possibly debri in your pump you should need no tools the face twist off and comes apart.your catch could be clogged too.
SOURCE: Whirlpool Front Loader machine will not drain
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
SOURCE: Whirlpool front load washer (model #LHW0050PQ4)
look at the drain pump. to remove nay water in the machine use a wet dry shop vac,attach it to the end of the drain hose.then remove the hoses from the drain pump and look fro any obstructions.if you do not find any thing then you may need to replace the drain pump or door lock mech,
SOURCE: Hello my washing machine works fine but when it
The drain motor may be bad click on the link below
