Minox 10x32 Br Ultravid Standard Binoculars Logo
Posted on Jul 27, 2011
I have a pair of Minox BD 8X32 BR binoculars and have lost the right adjustable eyepiece. Where can I get a replacement or have them repaired?
1 Related Answer
Anonymous
  • 14 Answers
  • Posted on Dec 30, 2010
SOURCE: The left eye piece on my Minox 8x32 binoculuars
In the US, you can contact Minox at 603-469-3080. You'll likely need to send them to Minox for repair service. Their offices out based out of New Jersey.
Regards,
Ben
Ben Lizdas
Sales Manager
Eagle Optics
www.eagleoptics.com
1helpful
Can I get a replacement eyepiece for my minox binoculars
Here is the link to Minox Repair Service with addresses and phone numbers to call for answers:
http://www.minox.com/index.php?id=4902&L=1
The left eye piece on my Minox 8x32 binoculuars isn't working properly. It doesn't adjust. How can I get it repaired?
Regards,
Ben
Ben Lizdas
Sales Manager
Eagle Optics
www.eagleoptics.com
4helpful
3answers
I have an old tasco 7x-15x35 zoom binocular. model #100. I lost the right rubber eye cup. Where can I purchase a replacement from........Thanks
You can't.
Tasco optical products are very cheaply made items, usually bought direct from whichever factory already makes the same or a similar model and then Tasco have their badges and packaging added.
They are consumer grade models which are not designed with longevity or repairs in mind; they're worth little when new and almost without value as used items.
The only repairs which can be done are by Tasco themselves whilst their products are under warranty. Except for the most minor of repairs, a warranty claim will simply involve exchanging the faulty item for a new one as any labour expended in repairs will often cost Tasco more than the wholesale price of a new unit.
Your only fixes are to live with the missing eyecup; to visit a binocular repair shop (not exactly commonplace) and see if you can buy an eyecup which can be adapted by yourself to fit; or to replace yours with another pair. You'll usually find that there are plenty for free on your local FreeCycle or Freegle group but they'll often have the even worse fault of a broken eyepiece yoke. But the price is right so it doesn't really matter if you have to collect five or six pairs before getting a good pair...
With all due respect, 7x-15x35 are going to be optically atrocious, so replacing your current pair is not a bad idea.
I wear glasses. I can't see through binoculars with glasses on or off.
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
1helpful
I have a jason 2000 and when i look through it i see double and was wondering how to adjust it back to be able to see right
You should be able to grab both sides of the binoculars and pull them together until the two images merge into one.. If you've done this already then the chances are that this model is too wide for the distance between your eyes (It happens more than you would think!!)
If this is the case, and they're new, you could try returning them to exchange for a better fitting pair..
Here are the instructions for setting up binoculars to suit your own eye-set and strength. You should be familiar with this when buying binoculars so you can test them in the shop..
The model you have is permafocus so you won't be able to adjust the focus but the first part should get you started..
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Oct 09, 2009 • Optics
I see 2 planes of vision on my 8x24 weaver binocular
Hope this helps...
1helpful
Double vision in minolta binoculars
Hope this helps...
Out of focus
Assuming you are focussing correctly. When binoculars are out of collimation the most usual effect is double vision as the optical axis do not line up. The only thing you can do is to take them to a binocular repairer. The problem is the cost. Proper repair need the use of a device known as a collimator and it is a laborious task to do it properly. Your binoculars do not carry a high monetary value and a proper repair will cost more than a new binocular of similar specs. Porro prism binoculars mostly have the objective lenses set further apart than the eyepieces. This holds true except for reverse porro prisms which are the other way round. Roof prisms have both the front and rear lenses inline.
Make sure when you focus that the first eye you use to focus with is the one where the eyepiece does not have its own focus ring (dioptre). The dioptre adjustment is on either the left or the right depending on the brand. That eyepiece should be left alone until you have focused using the center ring. Then leave the center ring alone and focus the eyepiece that has the adjustment ring.
Mar 12, 2009 • Optics
Top Minox Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Minox Optic Expert? Answer questions, earn points and help others
