Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
SOURCE: tv immediately turns off
Four flashes indicates a problem with the backlight on the TV. It can be caused by the backlight inverter board (the power supply for the backlight) or by defective backlights in the panel It is USUALLY the backlight inverter board that is bad, but I have seen both components fail at various times. This set is fairly new and should still be withing the one year warranty, so you should contact Sony at 800-222-SONY to get it repaired. Be sure to rate this solution. Thanks!
SOURCE: I have a sony LCD tv Model Number KDL-46V2500.
Try this link vor blink code info.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
SOURCE: MY SONY KDL-40S4100 IS ON STAND BY AND THE RED
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
SOURCE: My Bravia KDL-40S4100 lost all 3 of it's HDMI
There is a problem with the processor. The only way to resolve this issue is to replace the main board. It is called the A board in your TV.
There are two for this model and the correct one will depend on what your serial number is.
Part numbers are as follows:
part # 185709211 for Serial #
1,000,001 - 1,350,000
1,700,001 - 1,750,000
1,800,001 - 1,804,270
1,804,271 - 1,818,372
1,818,373 - 1,830,000
list price: $504.87 core charge: $680.00
part # 185709231 for all other serial numbers
list price: $505.87 core charge: $600.00
Testimonial: "Thanks, Now I wonder who all shares the same problem and if Sony is willing to do something about their defective products..."
