What should i do? would u mine pls to teach me sir?
I have an Olympus c750 and in the long version of the manual it says that the card must be unlocked just like you said. I think that you have to view the image or images on the card on your pc, right click on the image/s and highlight "properties", check to see if the box is checked "protected". If so, uncheck it and apply this to any and all images on the card. Something must have made the card write protected and you will not even be able to format it with the protection in place.
I don't know if You have all the literature for Your camera, Olympus usually puts out a short version, and a more detailed one. I am not familar with the 390, suspect some setting is incorrect. Have You tried leaving the batteries out long enough for it to return to defaults? Give it several hours, see what it does.
i own a Olympus AZ-1 digital camera..i too encounter the same problem of " write protect"..when i try to take it off by connecting to the comp..the setting just comes back...however i am able to format the card..but frequent formatting will spoil the memory card right??
please suggest some solution...
