no pc stated (hp what>? model)
Vista
came with IE7 and IE9 updated is best. and last. IE9 needs SP2 loaded.
best means max allowed on VISTA.
running IE9 are you, ? most older versions of IE are not supported
now at most top web sites,
due to expliotation weaknesses.
I would AVOID ALL IE , of any kind, IE11 will not loan on VISTA.
all IE version are not supported by MS now, they are all DEAD.]
means each day forward, IE will be exploited more... by the bad guys. Time to upgrade or drop IE period.
Run FF V55 ONLY.
(my recommendation to you)
Run EDGE. (personally I lothe it) , not on XP or vista , can't do that.
Run FF, v55+
never use IE again, in fact
forget it ever existed.
IMO
answer 2:
- your unstated OS is infected. corruption, reload it?
- your IE6 is full of malware rendering it useless like most are.
- or someone turned off javascrept in your IE brower.
- running vista with out SP2 loaded.
even back in 2010 many top web sites said
each web site in time dropped IE6, the 7 then 8,
they had to.
google IE8 support dropped
google same IE9 , id say most web sites support 9 and up.
so why not use IE9.....
upgrade to 9
or remove it and reinstall it if 9 if failing
and last read the offical page on wamart support
they do not support all browers 2001 to now, no.
https://marketplace.walmart.com/knowledgebase/articles/Article/Browser-Support-For-The-Partner-Portal?c=LifeCycle%3AMarketplace&kb=0
Thank you Janet Clark for you reply. Rommel Perona suggested I "tweak" my settings. I followed that advice in the security settings and still to this day have problems with IE9. I would not recommend iE9 to anyone. I have been using Firefox most times now. I had a computer guru work on my laptop and he could not understand why I can not access certain websites and download stuff that I want to download using IE9 but can on Firefox.
