Ya, for the good place to get the unlock code for your Samsung model mobile, just visit this site http://www.wickedunlock.com/samsung-u460-intensity-ii/rs11wp9/ , it provides the step by step instructions and easy methods for unlocking your mobile from the network lock........at the same time to get the unlock code you have to give some information about the mobile to this site that is your IMEI number,network & country lock after that within a short period you can get the code ..........If you unlock your phone using the unlock code then your phone gets permanently unlocked....After that, you can use it with any other network's sim card...........
SOURCE: Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
SOURCE: i switched my samsung hue
i switched my samsung hue from NAM 1 to NAM 2 and my phone turned off automatically.I had my phone set to lock on power up and now i cannot figure out my unlock code.
SOURCE: i changed the NAM type
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
