Question about Kyocera FS-1118 Printer
Error cf 223 error occurred power switch turn off and on again cf 223 for mita kyocera fs 1118
5 Suggested Answers
6ya staff
SOURCE:
Benimur
Louie Role
  • 6966 Answers
SOURCE: Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Posted on Jan 23, 2009
Anonymous
  • 330 Answers
SOURCE: i'm having an error on
this is
Controller system error
swith of and swith on the printer it will work .If this error occurs again even after the
power switch is turned off and then on
again, please replace
PWB
Posted on Sep 24, 2009
Mike
  • 167 Answers
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Posted on Dec 13, 2011
Kyocera 1020 error codes list
Hi Pandirayaj,
I have this manual for you to see errors in Kyocera FS-1020D. Hope it helps.
Kyocera FS FS 1020D Operation Manual Page 37 Error Messages
Apr 25, 2014 | Kyocera Mita FS-1020D Laser Printer
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Error cf223
CF2XX (CF223) errors are
Defective mainPWB.
If this error occurs again even after the power switch is turned off and then on again, contact the Service Administrative Division.
I hope this is helpful
Mar 15, 2011 | Kyocera Mita Kyocera CS-1820
Hi! Im just wondering for what use the (compact flash) memory card is, when installed in a Kyocera Mita FS-1010? (Beside firmware updates)
Found this in a manual.
Insert the memory (CF) card into the card slot located on the rear of the printer. A memory card is a microchip card that may contain option fonts, macros, forms, etc. The printer reads the contents of the card into its internal memory when printer is turned on. The presence of this data in the printer memory can be confirmed on the status page printout. For details of available memory cards, contact your Kyocera Mita dealer.
1 Turn off the printer. Never insert or remove a memory card while the printer power is on. Failure to turn the power switch off will immediately halt the printer with the four indicators turned on. It also could result in damage to the printer’s electronic parts or the memory card. Turn the power switch on again to restart the printer.
The only thing I have seen it used for (other than firmware) is to store certain info or fonts for forms (ex. tax paperwork or medical).
Hope this helps.
Jul 04, 2010 | Kyocera Mita FS 1010 Laser Printer
Kyocera FS1118, error code C6400, how do I resolve This?
Hi
Error C6400 appears in Kyocera FS118 when Zero crossing signal problem occurs i.e when the engine PWB doesnt detect the zero crossing signal. This can occur due to --
#1 Poor contact in the connector terminals.
#2 Defective power supply PWB.
#3 Defective engine PWB.
To reset it from Mainatince mode turn the power switch off and open the front cover. Now, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
4. After this is complete press the back key. The indication for selecting a maintenance item No. appears.
Daniel Scott
Jun 21, 2010 | Kyocera FS-1118 Printer
Kyocera FS1118 mfp gives error code CF 040 after start up
do a google search for the service manual and then lookup the error code in the service manual
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Jan 23, 2009 | Kyocera FS-1118 Printer
I'm having an error on my kyocera ecosys FS 1118MFP. The message is "Error Occurred. Power switch turn off and on again Cf2ff". Please can you help?
this is
PWB
Jan 14, 2009 | Kyocera FS-1118MFP Laser Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
Printer not printing - showing 'processing' but nothing happening
Reinstall the driver again, if it doesnot work, you have to update the firm ware of the machine, you can find this on kyocera website.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Nov 25, 2008 | Kyocera Mita KYOCERA/MITA - FS-2000D Mono...
Kyocera FS-1118 Printer Logo
820 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
