SOURCE: reset Apex DVD player
If you go to the system menu there should be a place under settings where it says Reset or Restore Default settings. Hope this helped. =)
SOURCE: Reset Toshiba SD-5000 Dvd player to factory defaults
With most Toshibas, you could un-plug them and leave it for either 10minutes or 30minutes and it would reset. strange, I know. give it a try.
I also found this when working on a similar problem with your player, it may be relevant -you could try pressing the power button and another button..
sorry, I don't have one in front of me to test..
[[power off the player
hit the power button and immediately hold the HDMI select button
the 3 HD indicator lights will cycle and then pushing the HDMI select button will move through the resolutions.]]
SOURCE: need code for Toshiba SD1700,or a Toshiba SD310V,
goto this web site you can unlock it here an its free
http://www.dvddemystifiziert.de/codefree_en/toshiba.html
