Can anyone help? Our machine stops in mid-cycle and flashes F04, even though the filter is clean (spotless after I cleaned it!) and the pump works quite happily draining it. Its supposed to be a blockage but I can't find one anywhere in the machine after cleaning it. Any other suggestions?
Basically it fills up, starts the cycle, then suddenly stops 5 minutes into it. I can get it to drain but nothing else. I see the F04 is a common problem with Bosch but can find few solutions.
SOURCE: Washing Machine Will Not Drain
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
SOURCE: washing machine
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump..
hope this helps cheers
SOURCE: bosch exxcel 1200 express fault code f04 what is
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go
off. Try the door gently. Means the machine is locked, for children. I think if you do
it again it locks.
Pl rate me 'very helpful' for the free help, thanks
SOURCE: USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is [email protected]
I have the same problem, Only I can't get the filter open at the front, the lugs have broken as I've tried to remove it. Any tips on removal
