Question about Samsung Digimax L70 Digital Camera
I'VE LOST MY SAMSUNG DIGIMAX L70 INSTRUCTION
  • Samsung Master
  • 5,638 Answers
Bypass Lock Screen on Samsung Galaxy without Data Loss
Android Lock Screen Removal & Data Recovery is a famous tool for removing password on Android lock screen without data loss. With the help of this program, you could bypass pattern/password on Samsung Galaxy lock screen without losing data.
Android Lock Screen Removal supports to remove 4 lock screen types on Android - pattern, PIN, password & fingerprints. Simple and easy to use. Android Lock Screen Removal works for Samsung Galaxy S/Note/Tab series, including Samsung Galaxy S9/S8/S7, Samsung Galaxy S6.
LEARN MORE
Broken Android Data Extraction How to Restore Data from Samsung Phone with not Working Screen Recover data from Samsung galaxy S9 S8 When Forgotten the Password Pattern Recover SMS from Samsung Galaxy S6 with Black Screen
Posted on Mar 15, 2019
  • 17,970 Answers
Visit this link Samsung-L70-Digital-Cameras-manual/id/563ag604/t/2/
Hope helps (remember to rate this answer).
Posted on Jul 28, 2011
6ya staff
SOURCE:
Camera won't read SDHC card, says card error when trying to format
If you look at the spec, it will only take an SD card, not an SDHC card. SD cards max out at 2GB.
Sep 17, 2017 | Samsung Digimax L70 Digital Camera
Samsung digimax L70 how to set time?
Select the "Date&Time" command from the setup menu.
Apr 23, 2012 | Samsung Digimax L70 Digital Camera
I've lost the instruction manual for my samsung GS 3650
you just follow this links
http://www.samsung.com/my/support/search/supportSearchModelResult.do?menu=SP01&searchWord=corby2&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=corby+2
Nov 01, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My samsung L70 camera is not holding the charge!! It does charge but it drains of power even before i get to use it, help please
Looks like it's time for new battery. EBay is a great source for inexpensive new batteries, Good Luck
May 03, 2011 | Samsung Digimax L70 Digital Camera
I have lost my instruction book can you help
You can download the manual from the manufacturer's web site at
http://downloadcenter.samsung.com/content/UM/200803/20080324103057703_English.pdf
Oct 11, 2010 | Samsung Digimax S630 Digital Camera
My samsung digimax L70 lcd got broken and i need to get a new lcd for it. where could i find a new screen?
You could buy it from :-
http://cgi.ebay.com/LCD-Screen-Display-Parts-Samsung-Digimax-L70-L-70-/280389738500?pt=Digital_Camera_Accessories
Good Luck!!
Thanks!!
Aug 18, 2010 | Samsung Digimax L70 Digital Camera
How do i hard resent my samsung Digimax L70 can
If you mean reset the camera by not using the "reset" function found in the menu, here's how...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jul 18, 2010 | Samsung Digimax L70 Digital Camera
Comes up with format then check sd card
I've had this problem too.
Your Samsung Digimax L80 accepts SD Card cards.The largest SD Card card you can use in your Samsung Digimax L80 is 2GB anything larger and it doesn't work.
Jun 03, 2010 | Samsung Digimax L80 Digital Camera
Samsung digimax L70, wont read any SD card, have tried 3 different makes. Tried resetting the camera and no joy. Camera starts up fine without SD card in but then i cant take any pictures. Any ideas?
Is the card properly inserted, try to check recheck and double check. cameras some times, give the guidance as a computer. it might be the card you got is not original, or was a product of a fake company. By the way how is the forecus of the camera. If you install the card in a computer is there anything appearing, in most cases there are people who temper with the genuin labels and most systems nowadays they are computerised to differantiate between the original and the fake products.
Welcome BeDeche.
Dec 25, 2009 | Samsung Digimax L70 Digital Camera
How do you change the time on this camera (Samsung Digimax L70 Digital Camera?
You can find the manual for your camera here: http://www.samsungcamera.com/common/manual_down.asp?prj_uid=551&fg_lang=EN&fg_site=COM
Simply select menu from the capture mode, then select date & time
Nov 28, 2009 | Samsung Digimax L70 Digital Camera
Samsung Digimax L70 Digital Camera Logo
116 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
