Ok, so you've successfully 'paired' your Bluetooth Headset with your computer. Now we're going to 'connect' the Headset so that you can start using it. There are two ways in which we can 'connect' our Headset. Both of the methods I'm about to tell you about achieve the same thing so really it's up to you how you want to do it.
Method 1: Note: The first time you try the following method, your Bluetooth Headset may not be visible in the context menu we're about to bring up. 'Right-click' the Bluetooth icon in your Windows taskbar and highlight 'Quick Connect'. Note: If you're unable to select 'Quick Connect', it's likely that you're Bluetooth Adapter isn't switched on so you should firstly, 'right-click' the Bluetooth Icon and select 'Start the Bluetooth Device'.
