Question about Nikon Photography
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
    New Friend:
My Nikon 35Ti film has same problem a repair part is needed 1s020-105 main PCB -no new part is available from Nikon! have to find on secondary market ! I'm looking too !
Posted on Sep 18, 2011
    Sergeant:
  • 217 Answers
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Posted on Jul 29, 2011
My nikon f65 wont recognise the film ??
Advance Motor gear(s) needs replacement
Jul 10, 2014 | Nikon F65 35mm SLR Camera
I have a Nikon FM3 and the shutter opens at the correct speeds but when I put B&W film in it (Kodak TX 400) and develope the film, there is nothing on the film like it was brand new. Help please.
Check to make sure that the film is properly inserted into the take-up spool, and watch the rewind knob and make sure it is turning indicating that the film is going through the camera. Also check to make sure that the multi-exposure lever isn't stuck in the on position by spillage or impact so the camera just keeps taking exposure on one frame and the film doesn't move.
Sep 29, 2012 | Nikon F3 35mm Film Camera
Nikon F65 won't auto-focus or take shots
You're on the right track with oxidation. Try cleaning the contacts in the body and on the lens with contact cleaner, and let it dry. Remove the battery, and clean the contacts inside the camera.
Mar 09, 2017 | Nikon F65 35mm SLR Camera
I have an error ( E) in the box for the number of photographs taken
That indicates that there is no film in the camera, or that the film is not loaded properly. It can also appear if you finish the roll and the camera has finished rewinding.
Nov 28, 2011 | Nikon F65 35mm SLR Camera
I was given a Nikon F65 SLR camera and my friend had lost the instructions manual...the step by step instruction one.not the specifications part...I'm not able to download that page....
Odd this is the second Nikon F65 for me to write on in the last five minutes.
Here is a link to a film page about half way down there will be two links for the PDF file for the manual. Yes the man is looking for $3.00 and if you are generous you can pay him most don't
http://www.butkus.org/chinon/nikon/nikon_f65_65d/nikon_f65_65d.htm
Gotta Love Film
Dec 28, 2010 | Nikon F65 35mm SLR Camera
How to see the picture after it has been taken for nikon f65?
The F65 is a film camera. You must get the film processed before you can see any pictures. If you have the setup yourself, you can develop the film. Otherwise, take the film to a photo processing lab (any camera store and many department stores, drugstores, and supermarkets either have them or have access to one) and get it processed. If you're shooting negative film, you can get prints. If you're shooting slide film, you can get slides. Either way, you can also request a CD containing the digitized images.
Again, the F65 is a film camera. The camera can't show you the images it has taken.
Nov 26, 2010 | Nikon F65 35mm SLR Camera
This is kind of embarassing... i received an old nikon f65, and i don't know how to remove the film properly without burning it...
The film should rewind automatically at the end of the roll. If it doesn't, press the two film-rewind buttons simultaneously for about one second. The film rewind buttons are maked with a red film icon; one is also the exposure compensation button to the right of the LCD control panel, the other is the auto exposure bracketing button to the left of the viewfinder.
Once the film is rewound, turn the power off. Slide the release lever on the left end of the body, and the back should pop open a little.
You can download the manual from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Aug 23, 2010 | Nikon F65 35mm SLR Camera
Currently I have a Nikon F65 non-digital camera with 28-80mm lense. I am planning to buy a Nikon D5000 DSLR. My Question: If i buy a Body on D5000 and will be able to use my f65 lenses? Will there will any...
If anything, you will gain image quality because the sensor on the D5000 is smaller than a frame of 35mm film. Thus you will only be using the central portion of the lens. On the D5000, the 28-80mm lens will act as a 42-120mm would on the F65.
However, you will lose autofocus capability. The D5000 does not have a focus motor in the body, relying on the lens having the motor, and neither version of the 28-80mm lens has a focus motor. The lowest-end Nikon dSLR with a focus motor is the D90.
Feb 07, 2010 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
I want to upgrade to a digital Nikon camera. I have a F65 and am thinking of a D50 or D70. Will either be compatible with a APO sigma 170-500 mm lens bought originally with the F65
Yes. Be aware that due to what's often called the "crop factor" or "multiplication factor" the lens will seem even longer, about the equivalent of a 255-750mm lens. This is due to the fact that the sensor on the D50 or D70 is smaller than a frame of 35mm film.
Jan 19, 2010 | Nikon F65 35mm SLR Camera
Display showing "E" and film is not getting forwaded
It sounds like the film transport motor is dead. If so, it needs a trip to repair shop.
be sure batteries are inserted correctly.
Jan 12, 2010 | Nikon F65 35mm SLR Camera
Photography Logo
159 people viewed this question
Top Nikon Photography Experts
Ric Donato
Jeff
Jeff
Richard C Cohen
Richard C Cohen
Are you a Nikon Photography Expert? Answer questions, earn points and help others
