SOURCE: my 8n (6 volt) will not start. Great spark getting
Spark to plugs is great?.....but if they are black (carbon coated) it may not start.
Crank her over and use that choke for 30 seconds.
Pull the plugs ...are they wet with gas?Smell it....is it water or gas.
They should be wet with something.
Are they dry.........No fuel.
If they are wet with gas and NOT black carbon coated and you are SURE you have spark..........time to tow it to start.
You want to turn the engine fast enough to have the crank throw oil onto the cyl walls. Engines need a oil coated cyl wall to run....to seal the rings.The gas from flooding the engine washes the oil away.Put it back and it should fire up.After the first start...it should be OK.
I've started many a engine that others could not start (flooded or sitting for years) with a little oil in each cyl to seal it.....but towing is the better choice if possible.
SOURCE: 8n ford wont start when hot,plugs are dry,ethar
Probably need to replace coil or condensor.
Might also check the starter, it could be dragging when hot and not letting it turn over fast enough.
You can order those online from www.Ford8N.com
SOURCE: 8N rpms keep falling
I run one number hotter plugs in my N tractors as they tend to foul plugs.
Glad it was a simple fix.
SOURCE: my 8n ford tractor has a new starter and started
The most likely cause of your problem is that the bendex drive on the starter is hanging up. This is caused by the return spring in the drive assembly breaking. First remove the battery cables then Pull the two bolts holding the starter to the block and remove the starter. It should drop out if it is difficult most likely bendex is still engaged just wiggle around until starter comes out.
NOTE: take caution as to not let end caps of starter come off. the bendex can be replaced by itself or you can purchase a starter with new drive bendex on it already.
to test if your push button is sticking take an ohm meter and test from terminal post to block or top of transmission where mounted if you get a reading of continuity then you have a bad starter button you can search for this part number 8N11500. The starter button just screws into the transmission cover and does have a gasket (pn 8N11529) and dust boot for the terminal. it is real easy to remove be sure area around is free of dirt you don't want that in your tranny.
No offence to HOGobal; putting a push button on the guage(aka dash plate ) is a bad ideal. The transmission mounted push button serves to keep the starter locked out if the tractor is in gear and yes the 2N,9N,8N,,NAA will start in gear and take off possiblely causing damage to your property,self and tractor. I have repaired to many push button remounts and have personally seen a 8n over come its park brake and run into another vehicle cause massive damage to the other vehicle. due to heavy duty push bar bumper assembly on tractor. Jack
