Here is what the F/H error code means;
FH
No water detected entering machine or Pressure
switch trip not detected. If after 30 seconds the control does not detect water entering
machine and then valves will be turned off and the error code will be
displayed.
Or
If the control has turned the water valves on and
after 8 minutes the flow meter has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will be
turned off and the error code will flash.
Press PAUSE/CANCEL twice to
clear the display.
Potential Causes
• If there is no
water in the unit:
- Make sure that both valves at the water source(s)
are turned on all the way.
- Check for plugged or kinked inlet hoses or
plugged screens in the inlet valves
- Verify inlet valve operation
If there is water in the unit:
- Verify Drain pump operation
Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire
harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter,
and Central Control Unit (CCU)
• Check all hoses for possible leaks
Verify pressure switch operation
• Verify flow meter operation
• Verify
CCU operation
If your fairly mechaically inclined this will make sense to ya,if not i recommend calling for service by a qualfied technician
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
Select the wash cycle and press the "Start" button.
If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
