You would connect an ethernet cable between the bluray player and wireless router. If the wireless router is too far away you would need a Sharp PLC adaptor
You just need an RCA cable. Find the output from your dvd and connect to the input of your tv. The cable has three connectors in three colors...red/white/yellow. Res and white is audio and yellow is the video.
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in. Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
