Question about Panasonic Lumix DMC-TZ3 Digital Camera
The screen is black and if I take a picture it is also black, I can view older pictures that have been taken
  • Panasonic Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Jul 31, 2011
Anonymous
SOURCE:
--cannot view anything to take a picture of--the view screen is black but I can see al menu items and can display settings. Flash works. I can see cannon signal clearly when camera is turned on. I am...
The A6XX series is prone to stuck shutter problems, particularly if the camera isn't used very often. Lens lubricating grease can coagulate on the shutter, immobilizing it. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 29, 2011 | Canon PowerShot A630 Digital Camera
I have an Olympus FE-330 The problem I am having is when I take pictures at night, focusing on anything is impossible. The view shows black, until the picture is taken. After the picture has been taken it...
Take a flashlight with you and shine it on what you want to focus. Press the shutter half-way, shut off the flashlight and press the rest of the way.
Jan 18, 2010 | Cameras
Black screen, black pictures
Set to auto shooting mode, take pictures, if still get black pictures, you need to repalce the lens unit. CCD or shutter defected.
Jul 08, 2009 | Olympus Stylus 720 SW Digital Camera
Panasonic Lumix DMC-FX8 camera and the viewing screen is black
You have a button on your camera for the view finder on top of the camera so you can look through and take a picture : or you can see the picture your going to take on the screen.Push that button and it will change it back . I learned this the hard way . I also thought I broke my camera.
Jun 04, 2009 | Cameras
All pictures taken are just Blackness
is there a view finder on this camera? often when there is a screen and a viewfinder there is a button to toggle between them, my sony camera has such a button although it is not a cybershot. i imagine the button says "dis" or "LCD" and just needs to be toggled. if the display were bad you would not be able to view pictures on it. display works must be configuration issue.
Jan 05, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Black pictures
it is worth to repair instead getting new, contact your panasonic service center
Oct 27, 2008 | Panasonic Lumix DMC-FX10 Digital Camera
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Image not visible on monitor screen
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Black screen
This is a system failure Tell Fuji Support about it but I fear any repair offer will be nearly the price of a new camera- unless of course it is still under warranty
Jul 12, 2007 | Fuji FinePix V10 Digital Camera
Black LCD screen and viewfinder in photo take mode
Sony (who bought KM) will fix this for free. http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Sep 05, 2006 | Konica Minolta DiMAGE A1 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
317 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
