This issue is related to a power problem. I don't think it's a lamp problem.
The problem is consistent with overheating on the power supply board of the TV.
The
power supply board of the TV has few capacitors and IC. If any of these
IC's gets short or become weak, it can cause the TV not to turn on.
When
current passes from electric outlet to the power supply board of TV.
The current also goes to the weak/faulty part, then the current stops
or slow and the board overheats and TV shuts off on it's own.
This is a
common problem faced by many other users too. To
solve this issue, check the power supply board and read it with a meter and
continuity tester, in order to detect the faulty part and replace the faulty part on the board which is
short due to which power supply board.
Sony specifically uses GM1 Board. In other words, Sony power supply board is called "GM1 board"
It's a bit
technical job but yes its not at all a costly repair to do or get it
done by the technician.
You
can buy these part at any Fry's or Radioshack store or you can
order them online at vendors like "mcmelectronics.com"(look for
electrolytic capacitors). After replacing these capacitor (capacitors)
most likely the normal operation will be restored. Or you can by a
refurbished complete power board to save you some stress.
If
this task is too technical for you, you can call a family or friend who
has the ability to assist you (two heads are better than one).
Good luck.
