Washing Machines Logo
Posted on Sep 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot find the model number on my Whirlpool washing machine. It is a top loading machine, with such features as: 4 Load size, 4 Tempature settings, 8 cycles, 4 speed combinations, commercial quality. super capacity plus. I kneed the model number to order replacement parts. Please help me if you can.
  • Anonymous Mar 24, 2014
    cubic size
    video on repairing
Anonymous
Level 3:
  • Master 1,543 Answers
  • Posted on Sep 01, 2008
Anonymous
Master
Level 3:
Answers
1543
Questions
Helped
751611
Points
5690
If this was a scratch and dent model, model number may have been removed prior to sale. If not, you should find it on the back edge of the washer at the very top as you look over the back of the machine. If you can't find a model number, bring the part(s) you need to a servicer. They may be common parts or there may be some identifying numbers on the parts themselves. Good luck.
No problem as yet. Just purchased a whirlpool front load top of the line. The instructions are very good except I can't find any instructions regarding adjusting the water level for smaller and la
For the Whirlpool WFW96HEAC front-load washer, the water level adjustment is made by the washer based on the size of the load. If only 3-4 items are in the tub, it will do a small load. If you fill the tub completely, it will do a large load. (Note: if the clothes are packed into the tub, they can't tumble and won't get cleaned.) Loading the tub with clothes until it is 1/2 or 3/4 full are the other load sizes.
Please add a comment with the model of your washer, I'll be glad to give additional help. I hope this helps.
Load size select nob is stuck in small load position & i can't get it to turn
the selector knob has finally taken a dump and needs to be replaced the part number you need is gonna be located on the back of the selector without a model number i have no way of looking it up for you
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
How do you set the Cabrio to wash a small load?
this one only has 1 setting on water level. same size uses same level
1helpful
I have the kenmore 90 series top load electric washer. Model #110.92291100. I am trying to find out if it's a 3cubic or a 4cubic size. I am replacing it and I want the exact same size. It says Heavy Duty...
I couldn't find the exact size using the model number provided... i would bet that it's a 3.5 - 4 cu.ft. model... My suggestion is to get something other than a GE washing machine... Go with a Kenmore, Whirlpool or Maytag
What cu. ft. size is my Whirlpool top loading washer model # LSQ9549LWO?
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
C1 code cant find model number on machine to validate service waranty
Whirlpool can get you into a range with your serial number, from there they need features and color.
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Whirlpool calypso washing machine
Could you possibly supply a model number and serial number. This will help greatly in determining the cause of your problem.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
