Splendide Model WD 802 . Would not drain water. Used shop Vac to clean out. Took off Drain filter cap and remove some coins trapped in ther. Now when I try to operate red lights go on but nothing happens. Door does not lock when I try tom cycle. Is it a pump problem or electrical
You need to take the pump out and clean it / dislodge anything stuck in it. Open the back cover of the washer dryer. Use a screwdriver to remove the hoses where the drain line attaches (both sides). Flip the washer dryer on its side. Take the 2 screws holding the pump to the frame out. Remove the pump. Now you may just need to clean stuff out so the wheel thing spins freely. Or you may be in my position where you have to disassemble the whole thing, pump covers and all, taking the motor apart and the pump off. Mine was "dead" but after doing this pumps like a champ again.
I have a Splendid Washer/Dryer combo Model # WD802.
The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
Anyone with suggestions for repair ? Thanks
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
