This is in case you cannot boot into windows but you can get into bios:
Open your disk drive. Insert windows operating system disk into your disk drive. Restart your computer.
If you can get to the stage where you can see see bios entry key then
keep pressing whatever key it is that you press to get into bios at
start up.
Select the option that let's you choose the drive to boot from, mine is
in advanced bios options. then go to either something like bios features
or change boot drive.select whatever drive represents your CD-ROM drive
and select it to be the first boot drive.
then save exit bios, I do this by pressing escape then Y to save and boot from the rom drive.
This will let you restart your installation of windows and
re-format the drive...
If you can boot into windows:
Then either re-format the drive and delete the partition when you do or...
Run a recovery of the system by installing your disk and letting it get
to the stage wher it asks what action/task you want to perform and
press r when prompted then follow the prompts to repair the files. This
might not work though,
you could even try running a disk check as maybe a lucky chance of repair if you can get into windows.
If your PC keeps trying to boot from the CD drive after repair then
re-enter bios at start up and change your hard drive back to first boot
device to boot into windows.
It's better if you re-format though as repairing windows can be a little tricky.
