Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
Posted on Sep 01, 2008
Kenmore elite refrigerator error code er if
I am gettting this error code on our Fridge, I have unplugged the fridge and it goes away for a time but has come back. Is there an easy fix or part needed.
  • 2 more comments
  • kayak4fish Sep 18, 2008
    No answers in over two weeks????? not much help here
  • worldwide247 Dec 26, 2008
    I have the same problem. Error "ER IF" the error comes back even if I unplug. My unt is about 16 months old.
    I wonder what sears can do for me?
  • bkzimmerman Feb 04, 2009
    I have the same problem eith the ERROR code. Did the fan motor fix the problem?
  • Anonymous Mar 12, 2014
    error code er rF
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Oct 05, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
10542
Points
18
Bad icemaker fan. When looking in the freezer, its the one on the left.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 31, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3117
Points
Wate is error code er f
2answers
Kenmore 795.78.402 refrigerator. Is the fridge main board bad?
Based on the symptoms you described, it is possible that the main control board of your Kenmore refrigerator is faulty. The fact that unplugging and replugging the fridge appears to have temporarily fixed the problem suggests that the issue could be related to the electrical components on the board.
The ER DH error code you received indicates that there is a problem with the defrost circuit. This circuit is responsible for melting any frost that may accumulate on the evaporator coils in the freezer, which can lead to a build-up of ice that affects the fridge's ability to cool.
A faulty main control board can cause issues with various parts of the fridge, including the defrost circuit. If you have already tried unplugging and replugging the fridge and the error code persists, it may be worth contacting a professional technician to diagnose the issue and possibly replace the control board if necessary.
How to differentiate between bad circuit board and bad fan motor in refrigerator
Full make and model in all questions please.
Causes of the Er rF Error Code An Er rF error code, as we've mentioned, indicates that there's some kind of problem with the fridge's fan motor; specifically, that the fan motor isn't running when it should be.
Dec 16, 2021
How To Fix Er rF Error Code On LG Refrigerator
I have frensh door kenmore elite fridge model number 795.72053.110 display error code if someone cane please help me ? ER F5 WHATS THE MEAN .... THANK YOU SO MUCH
faulty cercit board is what you have there sorry to say but it dose happen every so often get in touch with the poeple who you got it off and have the engineer look at it
3helpful
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
My kenmore Elite 795.77569600 fridge has er ff code
I pulled plug out of the wall socket waited a minute re-plugged unit in and so far error hasn't come back.
5helpful
Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
3helpful
3answers
Error message
Hello gravyblast.
Welcome to Fixya.
You said, your Kenmore Elite Trio, model 795.7756 or 7757 has an error message simply reading ER IF. No pressing of buttons, or combination thereof changes anything. Also, the ice maker has stopped working although it is turned on.
Can anyone help?
I cannot pull the refrigerator out to unplug and reboot it, thus I don't know what to do.
Try tripping the breaker off for 5 minutes and then see if this method resets the system?
Do not turn it back on for at least tree minutes. That's why I said, Five!!!
Lets see how it resets while I look your fridge up.
Write back. Huuum
7:11 pm eastern standard time . I'm here!
Fridge not working
Error code ER FF and evaporator fan makes loud noise
2helpful
5answers
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
