Xerox Phaser 3250DN printer BW laser Feeder Tray Logo
Anonymous Posted on Aug 02, 2011
Needing feed roller part # for a Xerox phaser 3250. The part # i do have 022N02355 is not the feed roller
Anonymous
Level 2:
  • Expert 304 Answers
  • Posted on Aug 02, 2011
Anonymous
Expert
Level 2:
Answers
304
Questions
0
Helped
202281
Points
741
5.6-83 JC66-00598A ROLLER-FEED
  • Anonymous Aug 02, 2011
    For Samsung ML-2851ND
How to replace tray 1 rollers
sir you can download service manual xerox 3600 in this link
http://www.itechmv.com/wp-content/uploads/2014/02/phaser3600.pdf
hope that it will help you
ERROR CODE PHASER 8560 07,010.43:69551 Replaced Maintance kit
. they replace a certain number of pages printed by the manufacturer data
maintenance kits are easily user installable and come with a fuser assembly, transfer roller, and pickup, or feed/separation rollers.
Xerox phaser 3117 paper jam problem, how to solve it
If paper jams every time, just open printer cover, pull out toner cartridge and you see paper feed roller it is rubber, just clean roller with alcohol and cloth.
I hope this help!
Paper is getting stuck at the begining itself in Xerox printer 3117
Open printer cover, pull out toner cartridge and you see paper feed roller it is rubber, just clean roller with alcohol and cloth.
I hope this help!
XEROX PHASER 8400 SAYS CLEANING SHEET NEEDED. THE MACHINE JAMS EVERY TIME WE TRY TO FEEED IT IN.
There is probably a tiny sheet of paper stuck inside the printer somewhere which is causing the jam. You basically have to find out where the previous jam was and check the rollers to see if they are clear.
If it is cuz the cleaning sheet is too stiff, then you may need to feed it from the manual feed tray.
Xerox 3117 paper jam
I hope this help!
Xerox Phaser 6120 cannot feed paper without help
As this is an old posting I should imagin you might have it sorted by now.
if you have these type of problems clean the feed in rollers with a alcohol wipe or similar. There is usually a solonoid / clutch release mechanism that controls the paper selected from tray. I would go for the simplest solution. Over time the rollers get coated in paper lint, clean water is usually best if that fails perhaps an alcohol wipe might improve matters.
Good luck.
1helpful
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
1helpful
Can I disable the lower print tray?
Hi wogan2:
Normaly when you get this problem it means that you need to replace the feed rollers in that tray.
Inspection
Rollers:
Replace the rollers when you see any of the following defects:
 Flat spots
 Out of roundness
 Cracked rubber
 Loss of traction (tackiness) causing pick or feed failures.
Xerox paper pick roller
Part # 401-0882-00
Hope this helps
2answers
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
