Brinkmann 5 Burner with Smoker 8101750S Logo
Posted on Aug 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a gas smoker and grill from Brinkmann. I am not sure if I am using the smoker correctly. I soaked the wood chips and placed them in the tray. Once I turn the gas on and place the chips over the flame, is there anything else I should do to these chips while the meat is smoking?
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Aug 03, 2011
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3799630
Points
33142
Hello wham.... go to this link http://www.brinkmann.net/customer_service.aspx Here you can download the owner manual, get other info for smoking meat, and even sign up for a periodic free newsletter. J.
Where do I put the wood chips in?
this depends on the type of appliance you are using A smoker or a charcoal barbecue will use chunks instead of chips so I'll assume you have some brand of gas broiler that does not have a drawer or cavity for wood chips engineered into the design of the appliance.
In this instance you can soak chip overnight and loosely wrap them in aluminum foil. Place the loosely wrapped chips over a burner on the radiant tray or briquette tray so the heat is directly on the wood chips.
Close the hood and keep the other burner off or low so the heat on the wood chips soaked overnight causes them so smoke and not char. You need the wood chips over the flames so they smoke.
Oct 18, 2014 • Grilling
2answers
How to cook a brisket. I ahve lost my manual.
Hi judyyates...
To use your Brinkman Smoker or Other Smokers
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or overnight in the refrigerator.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water, 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will do the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
3...Start a fire in the smoker having the fire below the meat, but do not put the meat on yet, wait till the flames die down first.
Once they are coated with gray ash, you can place the meat on the racks and add your soaked chips to the smoker.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat if you are not using a water pan in that position.
4...Place the meat in the smoker on the grilling surface, and place the wood chips over the charcoal and hardwood in the main grilling area Close the lid and do not open it unless you must add wood chips during the cooking process.
5...Continue adding wood chips to the tray as needed during the time you are cooking.
If you have a Brinkmann or other smoker with one chamber for placing the wood chips and the meat, add wood chips only once per hour.
6...Apply your sauce to the meat one hour before the meat should be done.
Test your meat with a thermometer for for an internal tempreture of 160 degrees for medium and 170-180 degrees for medium well to well
Note: Apply the sauce quickly to avoid loosing the heat in your smoker if you leave it open too long it will allow the heat and smoke to escape, increasing the cooking time.
Close the lid if it needs to continue cooking till you reach the right internal tempreture
7...Test your meat with a meat thermometer after a few hours of cooking time.
Make sure your meat is at least 160 degrees internal tempreture for medium and more than 170 degrees for medium to well.
Close the lid and maintain your heat if it needs to continue cooking.
I will also include a link that will interest you below.
Please take time to rate me.
http://www.smoker-cooking.com/howtosmokeabrisket.html
3helpful
2answers
How do I smoke in this Smoker/Grill? Like where do I put the Smoker chips there is no smoker chip box, just the pan for the charcoal and a pan I think for water.
Hi karin 1967...
How to use a char-broil smoker (charcoal) with wood chips smoking briskit. ( what temature should the grill be at ?)
Hi hcf6886...
Sep 18, 2011 • Grilling
There are not directions on how to use the smoker. Do you have have any instructions on using the masterbuilt smoker model 20020611
Hi dan480volts...
Maybe this will help you
2helpful
Do you put the wood chips directly on the heating element?
Hi bobsbbq3u...
I am sending you some smoking information on how to use your smoker..
When using chips for smokers do you dump them as soon as they start burning
Let the grill heat up first and stop flaming if using wood..
After the grill is heated up to temp your going to smoke at then you add the wood.
I will include some info for you also to help.
2...Cover your wood chips with water(and if you wish you can add some Jim Beam Whisky or other flavorfull liquids in a bowl with the water 1 inch above the wood chips and use a flat peice of metal (pie pan,etc.)to weigh the wood chips down underwater.
You will soak the wood chips at least 24 hrs before you plan to start smoking this gives the wood time to soak in the flavorfull liquids.
1helpful
I do not have manual for using brinkman gourmet charcoal smoker
Hi tsanelli...
I could not find your user manual on the net, but I have this..
1... Marinate or place a rub on the meat you will be smoking, and let it sit for a few hours or over night in the refrigerator.
3...Start a fire in the smoker having the fire below the meat, use hardwood or charcoal,
Once they are coated with gray ash, you can place the meat on the racks.
I would place an aluminum drip pan under the center portion of the cooking area on your smoker, to catch the juices from the meat.
How do you burn the wood chips
The pre-soaked wood chips are placed in the cylindrical wood chip holder on the side of the unit and then inserted into the smoker above the wood chip tray. The wood chip tray must always be in place prior to loading the wood chip holder.
To further assist you, in case you have misplaced the Owner's Manual, I have included a link to it, that you can download and print for future reference. It also includes recipes.
http://www.appliancefactoryparts.com/content/pdfs/135884-1.pdf
To extend the use and longevity of this smoker, be sure to follow all the routine maintenance suggestions in the manual.
Hope this helped you to enjoy your smoker. Thanks for choosing FixYa.
We have mislaid operating instructions. How do you work it?
This link should help you get a new set of operation manuals.
http://www.brinkmann.net/products/details.aspx?item=810-5301-C
The basics of this unit is, load up the charcoal pan, fill the water tray up about 2/3 full, have some wood chips soaking overnight, pick your favorite recipe for a smoker (try smoker burgers!) umm and easy for the first try.
Get your charcoal going assuming not the electric model, place the meat on the grills, close lid, try to maintain about 225 temps, add your soaked chips on top of the coals, check you temps, add more charcoal when the temps start to drop on long cooks. You should be able to smoke some burgers in about an hour and a half. Low temps and slow cooking is the key.
I hope I have helped you out.
Top Brinkmann Grilling Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
