Hi If the washer won't fill you'll need to check for the water
inlet hose, the water inlet valve and the pressure/water level switch assembly.
Inspect the inlet hose coming to the washer for any blockages. If the hose is
not clogged then check the water inlet valve for any clogs, if the water will
not even fill for few seconds then certainly the water inlet valve is bad and
should be replaced. You can also use a multimeter to check continuity on inlet
valve. If you don't get any value on the multimeter then you'll need to replace
the water inlet valve assembly. However, if the valve is fine then the
pressure/water level switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
Hello friend, I appreciate your post!
Based off the information you have provided water is not entering your Frigidaire washer. Are the house valves turned on fully? Check to make sure that the house valves are turned on and if they are check to make sure the water hoses are not kinked or pinched.
The problem could be within your water pressure, pressure switch, or water inlet valve. I would recommend reaching out to a professional for further assistance regarding your washer to avoid any unnecessary part purchases. I hope this has been beneficial. -Matt
