Question about Dell Axim X5 Pocket PC
Help active sync will stay in limbo attempting to connect to cradled axim
I have problems with my axim being connected to my laptop. First of all, I followed the instruction to install, outlook then active sync3.5 then when prompted plug in the cradled axim x5. But the active sync will not connect properly, it will connect and disconnect, or sometimes it will not detect the axim at all!!! I tried restarting my laptop and no help. I tried to change a usb port and no help. I tried to remove the axim from device manager and then try again and still no help. I tried to uninstall active sync and then reinstall and still no good. I even tried with active sync 3.6 and its all no good.
    Master:
  • 852 Answers
Does your system detect the handheld? After you connect the cradle or cable to the computer, then you should be prompted to install drivers for the handheld. Make sure that Dell Pocket PC appears in the Device Manager.
Posted on Sep 13, 2005
6ya staff
SOURCE:
Axim x51v won't sync
Guys it's probably down other sync software on your system like phone sync, I had the same problem yesterday, sometime ago I had installed software for my HTC phone, check in add/remove programs & uninstall anything that sync with your computer, then reinstall activesync.
welshcob
Jan 03, 2013 | Dell Axim X51 Pocket PC
Does not recognize my connection for active sync
Dell made an entry into the market of Personal Digital Assistants (PDA) with Axim X5. The Dell Axim comprises of families of X5, X3, X30, X50 and X51. The Dell Axim PDA can be connected to the computer either by using a cradle or a sync cable. The sync cable connects the device to the computer directly. Here are the steps for connecting a Dell Axim to a computer using a sync cable.
  1. p 1 The Microsoft ActiveSync software must be installed in order to connect the PDA to the computer. This software is found in the Dell Axim Pocket PCmag-glass_10x10.gif Companion CD.
  2. Step 2 The Axim X51 PDA has a 36-pin connector, while the X3 has a 22-pin docking connector.
  3. Step 3 Connect the USB connector found at the end of the sync cable to the computer.
  4. Step 4 Check the PDA. If the PDA is not properly cabled to the computer, you will get the following message: “Connect your device to a computer using a sync cable or cradle before running the system update. Ensure that ActiveSync is installed on the computer and that the ActiveSync connection is successful.”
  5. Step 5 Ensure that the Dell logo faces upward.
  6. Step 6 Use the sync cable to set up a partnership, which can be done multiple times when you sign in as a guest.
Nov 14, 2009 | Dell Axim X3 Pocket PC
How to connect Dell Axim X51 with the desktop computer
You need the cradle or the usb cable for the axim and get Active Sync 4 installed on the computer.
Jun 16, 2009 | Dell Axim X51v Pocket PC
I cannot get my Dell Axim X5 to sync to my laptop
Well windows vista doesnt need any software to run the axim, it has a hardware feature on it to detect and sync to it. Ive never heard of this. I would be able to help better if i was in an instant message session with you and able to see things better. If you have google my account is: clintchance if YahoO! clintchance1101 hotmail: clintchance@hotmail.com (yeah i know, i dont like to change the username often.) If you can contact me on one of those i can help you better. Im usualy on after 3:00 PM CST
Jan 13, 2009 | Dell Axim X5 Pocket PC
How to connect it to a pc running Win XP
Simply download the active sync from http://www.microsoft.com/windowsmobile/activesync/default.mspx
And use the USB cradle to connect to computer (You can also use Infrared and Bluetooth). As long as active sync is on the computer system will recognize pocket PC automatically
Good Luck
Jan 27, 2008 | Dell Axim X3 Pocket PC
Dell Axim x51 will not connect to system
windows vista uses its own sync software, which is available on the windows marketplace
if your vista is original you can upgrade to this software
if you use xp version, just keep using the usual active sync
Oct 04, 2007 | Dell Axim X51v Pocket PC
AXIM Disconnecting
Go to Start Settings System Power Control Uncheck (On external power) or set it to what ever mins you want
Sep 14, 2005 | Dell Axim X5 Pocket PC
Help with Avantgo
You don't really need for it to. You can go to setting on your Axim, then to connections, and use the avant go connection, to connect, and synch with avant go that way. You can synch to avant go that way, with any internet connection. If it's connected to active synch as a guest then you can't synch with active synch also.
Dell Axim X5 Pocket PC Logo
159 people viewed this question
Ekse
Alun Cox
Thomas F. Schneider
