SOURCE: samsung tocco 480 screen is cracked/broken
The screen should keep working with the LCD cracked. i.e you should be able to receive calls.
You can find replacement LCD screens for Samsung F480 in this link:
http://www.pantallas.biz/epages/wwwpantallasbiz.sf/en_GB/?ObjectPath=/Shops/160419/Products/F480
I hope it helps.
Ignacio del Olmo
SOURCE: Can't turn the keypad tone off when i text - samsung tocco f480
You've probably found out by now, but I've been tearing my hair out to solve this and have finally done so today. Menu -> Settings -> Phone profiles. Then select the righthand double arrow icon for the profile you want to change (likely 'Normal' at the top). From the pulldown list at the top right, change 'Incoming...' for 'Phone sounds'. Scroll down to the bottom of the resulting screen (using the lefthand handset buttons if, like me, you have trouble scrolling) and set the 'Phone sound volume' (slider control) to '0'. Then hit 'Save at the bottom, and job done!!! Phew!!!!
Neil J
SOURCE: how do i turn the keypad sound of on samsung tocco
I had the same problem so called Samsung UK. Take following action: Choose - Phone Profiles/Normal/red chevrons/top right drop down menu/choose phone sounds/scroll to bottom phone sound volume, put to zero and press save. It works! Hope this helps. Julie J
SOURCE: 'No Event' has appeared on the touch screen and I
very easy issue. touch your screen so that the side widget pops out from the left hand side. then simply touch the "no event" and slide it right on over onto your side widget then close it by touching the centre of the screen
SOURCE: could you tell me how
Adjust the volume of the key tones
In Idle mode, press [up /down] and adjust the key tone
volume.
Adjust the vibration intensity on the
touch screen
You can adjust the intensity of the vibration when you
tap the phone screen.
1. In Idle mode, press [up /down].
2. Select Vibration and adjust the intensity of the
vibration.
