How do I fix my Outlook Calendar synchronization problem?
None of the items in Outlook Calendar are synchronized to the LifeDrive, even if I do a 1-way transfer to the LifeDrive. LifeDrive started out with no Calendar events (this was a first time synchronization) and ended up with none, even though Outlook had at least 20 Calendar items in it. Tasks, Contacts, etc. all synchronized properly, everything but Calendar.
Re: How do I fix my Outlook Calendar synchronization...
Palm tech fixed my problem.
It turned out some items in Outlook Calendar were corrupted, thus preventing a synch with LifeDrive. The fix is to export the Calendar items and import them. This process fixes corruption. After doing that I successfully synchronized Calendar with LifeDrive.
More specifically. I moved Calendar items to a different folder, thus emptying the main Calendar folder. I exported the Calendar items in the new folder to a CSV (Windows) file. Then, I imported that CSV (Windows) file into the main Calendar folder. Finally,I did a synch and all worked perfectly.
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here 2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
This morning I downloaded LifeDrive Update 1.0, and when I did a HotSync afterwards, I got an error message saying,
Handheld Tasks application database version not supported.
Handheld Notes application database version not supported.
Now my contacts, memos, tasks, calendar entries and possibly other items are all gone!! This is the core data that is the reason why I use a PDA! I would be totally distraught, except that the data does still seem to exist in Outlook on my PC.
I am running Outlook 2002, SP3 on a WinXP machine. Can anyone help to fix this problem?
thanks,
You may have tried Exchange ActiveSync in VersaMail
When you setup an Exchange ActiveSync account in VersaMail, you are asking your Treo to synchronize email and your calendar with an Exchance 2003 server. In order to prevent duplicates, VersaMail disables Calendar synchronization via HotSync while the account exists on your Treo.
So if you are an Exchange ActiveSync (EAS) user, you have a choice; you either sync wirelessly or you can delete the EAS account in VersaMail and can then sync your Calendar via HotSync. You cannot do both unfortunately.
Fix in Outlook??
Isn't there a way to keep private appts from showing in Outlook? Perhaps you could change the setting on that side?
Did you have trouble getting your LifeDrive to sync w/Calendar in the first place? I've managed to get all BUT calendar syncing (and it's the MOST IMPORTANT part of Outlook that needs to sync!!)... any advice?
Generally this error means that HotSync manager (via the 4 Outlook conduits) is having a hard time connecting to your Outlook or, in some cases, specifically to your Oultook profile.
I was having the same problem, and I used Detect and Repair in Outlook. Now all is working fine. You will need the original CD that you installed from.
Hope this helps as none of the other things that I saw on any sites did until I tried this.
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
what software did you download for your outlook conduits? the installation cd already has the outlook conduits you need.. you just have to install palm desktop first then you'll be given options whether to sync your handheld with palm desktop or with outlook. choose sync with outlook
Updated Instructions
Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650).
1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu.
2). Turn off phone.
3). Set the Date/Time to the maximum limits (12/31/31) in Preferences.
4). Open the Calendar and view the maximum day 12/31/31.
5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu.
6). Reset the Date/Time to the current day in Preferences.
7). Hotsync (Desktop Calendar overwrites handheld).
8). Hotsync again to make sure you don’t get the error (Synchronize the files).
That’s it.
Outlook Calendar
The attempt to open the database failed.
Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize.
OLERR:05-0001
OLERR:0D-0004
OLERR:0D-0001
- Not Synchronized
Outlook Calendar synchronization failed
OLERR:15-0002
OLERR:06-0001
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
