First, I'm not a Payne Tech.
* All repairs on Air conditioner equipment should be performed by a CFR certified technician.
* Check your warranty and call for service.
*** the following is for information only ***
* If this is a Home air conditioner unit and not an auto part then the drain pans (there are several depending on use) should be at the bottom of evaporator which should be removed during maintenance for debris clean up (causing a clogged drain).
* Some refrigeration units use pans with or without drains. It depends if the water (condensate or defrost water) can be removed using a drainage system. If there is no drainage nearby then a condensate collection pan is used. It has a water heater in the pan that activates when the pan is filled or comes on with the defrost cycle. You usually only see a collection set up in stores where the refrigerator is in the middle of the display floor with no drainage near the display. (they also don't want customers tripping over a drain hose.)
* The spec data does not show the drain pan. Only the location of the drain. ;
http://dms.hvacpartners.com/docs/1009/public/08/ss-pa10-09.pdf
* This unit is normally mounted outside of the building (in the weather). Regular scheduled maintenance is required for this type of unit to work properly. The tech will usually clean out the bottom drip tray (if it is fixed in place). He may use air or if done properly, with water spray.
* Be safe. Have a certified A.C. tech service your equipment.
Aloha, ukeboy57
